Project black hole sun.
The MAF reports to the PCM the amount of air mass flowing through it, the higher the engine RPMs is the more air mass will be flowing
The PCM looks at that amount and commands what amount of flow needed by the fuel injectors for the correct AFR
Any air leak after the MAF than is unmetered so more air is leaking in and PCM is still going by what the MAF reported
The end result of unmetered airflow is the AFR would be really way too lean and only the O2 sensors would report lean and confuse the PCM
This causes incorrect fueling and lean AFR which causes engine to run poorly so if a slight air leak is a negative to how engine functions
The stock air bridge coupler is not smooth as the engine had slight movement on the motor mounts and that flex type of coupler is designed to handle that movement
A smooth type will work but not as well as stock one and any vendor claiming performance gains for a coupler is FOC
You want zero air leaks from filter to throttle body
Dorsetsteve
Very much understood coming from a twin turbo car with over 30ft of induction piping and the MAF at the start! All sorted now and hence why I think it’s wise to sort that pipe before it becomes a problem. Same with the other car, has two of those type joints and the consensus that removing them has no benefit.
Due to air leaking, is how long in time/miles it was as the leak would cause real lean AFR and cause PCM to command far more fuel injector flow which would cause more carbon buildup, and you should use a decarb product in oil and gas to help clean out and check spark plugs for carbon buildup, this also would help clean the fuel injector nozzles from carbon
Also with that PCV connector not correct would cause PCV system not venting oil fumes correctly
Dorsetsteve
What would be the best option with this vented consul? The draw by the temperature adjustment is faulty. The cup holder is also damaged. It would seem to me that replacing it complete with a later one that’s not silver/grey would be a sensible option. But where to buy?
Could you not take it out, fix it, and then spray paint it the colour of your choice? Fail that, I guess you could see if there are any breakers around and nab the part from them.
Me being in the USA, what does The draw by the temperature adjustment is faulty, and where is it located ?
I confess I assumed he meant "drawer" (as in a set of drawers - pull out storage shelf type things like in a bedroom cabinet), and then assumed the reference was for the little storage area in the photo immediately above the gear stick and stretching over to the cigarette lighter / 12v power socket. The door for it appears to be hanging down, so maybe the door for it doesn't stay up any more, and thus broken.
Dorsetsteve
Thanks for the reply guys, it’s both the cup holder as highlighted by teamzr1 and the cigarette lighter door. Assuming that’s all one assembly screwed together, replacing the lot from a breaker would be the most efficient?
