Project black hole sun.
Blackzed
On my C5 Z06, they were put into the side gills, so you couldn't see them from the side. Also a bit of tint applied and they almost disappeared. BILD0348indicator.jpg
Dorsetsteve
I did consider popping them into the gill but thought it gave better visibility to other road users being surface mounted, I even toyed with them being on top the gill for the same reason as per the U.K./European spec. Settled on the halfway point and went in the rebate.
Dorsetsteve
I can’t recall if I’ve asked but has anyone got a recommendation of an OBD2 scanner to read the codes? I’m getting “Service Active Handling” fault. Which could be one of a number of things but without the ability to scan the ECU il be shooting in the dark.
Dorsetsteve
Got round to fitting the front lip.
The passenger headlight was pretty poor with UV damage so I attempted to tint them temporarily before having to remove them etc, this didn’t go very well. So ahead of budget schedule I also have new headlights which arrived are sat on the shelf ready for some time to fit.
