Morning All. I see that a lot fit longer bolts to lower the rear ride hight. A lot of c3’s seem to sit down a bit more on on side or the other. Min seems to on the drivers side. My bolts are 6 or 7 “ from memory . The nuts where they sit are nearly at the end of the threads. If I wound Up the nut on the drivers side, that should raise that side ? . Anyone else had similar and corrected or improve it in this way.? (Vette has newer composite spring , newer rear shocks and the chassis was re jigged at a frame shop in the usa when the body was off) any thoughts appreciated
