Boy, that really pisses me off after all these weeks
That shop is the one that bricked your PCM and should have replaced it back than on their money
I even did some searches and pointed the 1994-95 PCMs, new and used to him, I found
He emailed me two days ago asking me what you're asking here and also sent me raw GM code I have no way to look at
I do know which of the I/Cs in yours is the calibration flash chip
Only can show what flash chip looks like on a C5 PCM as I removed memory flash chip and soldered in a I/C socket so flash chip later on
simply pulls in and out
Bottom photo is stock and can see the shape of the flash chip
Top photo is after I installed an I/C socket, what a pain in the balls to work on surface mounted I/Cs :-(
