Quick look on the internets to see how much they are, and needless to say I'll be saving for a bit longerAFR Eliminator with Magnum 270 cam
I'm hoping to pull a plug sometime soon - just waiting for my new plug removal tool to arrive, and also some spare time when not looking after a baby etc.If in doubt, take one spark plug out and look at the head where the plug installs
If the surface is flat than not seated ,and if the surface shows tamper than for tapered type
Careful selection of your cylinder heads can make all the differerence in power and, more importantly 'streetability', and surprisingly perhaps economy (lets say 'relative' economy). You'll select the carb, the inlet manifold, headers and cam to hopefully suit the characteristics of the heads .........but that key selection is the cylinder head, its where the best money is spent.Quick look on the internets to see how much they are, and needless to say I'll be saving for a bit longer. So many head choices with the various CC versions - 185, 195, etc.... though looking at the names, anything more than 195 is labelled as "race". So probably not for me. Mine is more "my car was labelled as 300(gross)hp when new, and I want it to have at least 300(net)hp now, and be nicely streetable".
Yeah, I was looking around on the internet and its just overwhelming as I have no idea. Fortunately, I also have limited money for these kinds of things so I'll be leaving it for a while.but that key selection is the cylinder head, its where the best money is spent.
I think you said you’ve got a 3.08 diff, (same as I have) which is a good thing with the 4 speed manual to stop the engine buzzing so much. The trade off is a 3.08 kills acceleration a bit, so you really do want good low and mid range torque from the motor to compensate. That’s why I went stroker and kept to a sensible cam.Yeah, I was looking around on the internet and its just overwhelming as I have no idea. Fortunately, I also have limited money for these kinds of things so I'll be leaving it for a while.
In an ideal word, I'd like <whatever heads> fitted with a nice multi-injection system like the pro-flow 4, and be running a nice streetable engine running 300hp - I'm not looking for a max revs monster, as I have one of those in the form of the 8k+ FTO. But something that pulls well from idle. I'm not greedy, I just want my engine to run at least the 300(gross)hp it was rated at - but in more modern 300(net)hp instead.
I might see if I can find some local engine builders and see what they suggest.
Agreed. From memory, when I had my 327 tuned a bit on a rolling road, the bhp may have been down a tiny bit to around 250bhp ish. But the torque was almost a flat line from idle up to max - around 280 - 300 Lbs/ft. It certainly does pull well from low revs for a "small" engine capacity and 3:08 gears.For 'street' applications (and performance too) a 'revbox' isn't the best way forward anyway - mine makes all its real power between 3000 and 5800 rpm....yet is really very tractable with good street manners between 1500 and 2500 rpm.......typical street usuage. For real indication of usable power always follow the engne torque curve.
You know, I took my Vette out for a blast around the roads near me, mostly small roads and some B roads. I'd forgotten how nippy and fun it actually is (not driven for awhile as I've been slowly tinkering with it).
I really don't think I need that much more power in it as then I'd have to drive it a bit more carefully - at the moment I can gun it everywhere and not worry about it getting out of line.
It looks like it says "FS" on the plug that is handily facing upwards that I checked. I can check other plugs in case a bit of it has worn off from "ES" to become "FS", but unlikely as the text was very clear and sharp.Those plugs could possibly be the resistor version of what I'm using......albeit a couple of numbers 'hotter' in heat range terms.........BPR5FS........is that FS or ES
