Just an FYI
The 97-00 base Corvette used 26 lb/hr fuel injectors
Starting in 2001 increased the injectors model that flows 28 lb//hr so do not use the older ones for 2001-2004,
including the Z06s that put out more HP/Tq and require the higher flow model as older model would cause the engine to run too lean at
higher engine loads
