stealthyflatfish
Do the t tops on C3's always rattle and squeak, seals all good, cleaned and tops tight? Drives me nuts!
Ok Ross, that's it then if the sun's not out and the tops not off, it ain't moving.Yes.......(except when stationary)
Often the clear plastic grommet needs renewing due to wear on the "B" post where the "T" Top bolt locates other factors; adjustment and weather seals worn allowing more free movementDo the t tops on C3's always rattle and squeak, seals all good, cleaned and tops tight? Drives me nuts!
I'll check the fixing holes then use polish on the seals. ThanksRub into the t top, door bonnet rubbers furniture spray that has wax in it, Mr Muscle, Pledge etc.
As long as it has no silicone, silicone attacks rubber!Rub into the t top, door bonnet rubbers furniture spray that has wax in it, Mr Muscle, Pledge etc.
I wouldn't think the seals are pure rubber Tony, more a man made substitute containing a miniscule amount of rubber, perhaps red rubber grease might have been an alternative, but if the seals fall apart in the next 10 years I'll give you a shout...... LolAs long as it has no silicone, silicone attacks rubber!
When I get that shout in 10 yrs time my reply will be โI told you Stealthy didnโt iโI wouldn't think the seals are pure rubber Tony, more a man made substitute containing a miniscule amount of rubber, perhaps red rubber grease might have been an alternative, but if the seals fall apart in the next 10 years I'll give you a shout...... Lol
