Three bladed relay unit for indicators (not hazard flashers)
Nigel curry
Hi all
i am looking for a relay for my 1976 coupe but I want the electronic type as there seems to be a weird mix of led and normal bulbs on the car,and I have read that the electronic relays can handle a mix of either, I just want to get the dam things working so I am embarking on a process of one step at a time,however I will need a three spade connector type and was hoping you guys could suggest some people to contact
thanks nige
Interesting that Classsic Car Leds offer a dual filament LED amber and white bulb that will be of interest to those of us ('68/'69) Vettes with combined white/clear front indicator lamps.
Many years ago I simply replaced the stock clear lenses with early Land Rover/Moggie Minor (and others) amber lenses. Yes they 'flashed' amber and therefore UK legal - but were now also an amber sidelight (not legal) as such..........however.......
The white front sidemarker lamps (certainly on '68s and '69's are kinda visible from a frontal aspect.......so I'm effectively showing a white light to the front (complying with legal requirements) and additionally showing an amber light to the front too. It isn't illegal, perhaps classed as an auxillary driving light. I've never been 'pulled' and never historically an issue with MOT's.
The dual filament LED bulb that Classic Car Leds offer is the logical answer and something I'll get around to changing at some point.
1968 rear lights are the only C3 year with 4 no. dual filament stop/tail lights. Back-up lights are in the rear valances beneath the bumpers.
'69 and onwards C3's are fortunate to have a one pair of dual red/clear lenses that provide back-up lights.......obviously many C3's will have a pair of these 'given-over' now as indicator lamps using amber lenses. The 'real trick' will be to see if these dual filament amber/clear led bulbs are usable for both back-up and indicators.
BA15D DUAL COLOUR WARM WHITE AND AMBER SIDELIGHT AND INDICATOR TURN COMBINED LED GLB381 LLB381 381 SWITCHBACK
I didn't use the ones from Classsic Car Leds, but I have got amber and white switchback LEDs in my rear lights and they work very well, although I've used ballast resistors with the indicators so that they work with the standard flasher unit.
TimP
Classiccarleds have been my go-to suppliers for my '72 LED lighting (and more recently for the 92 C4 H4 headlight bulbs). For the '72 I have used the 2 pin (with flying earth lead) indicator relay...
...and it has worked very well.
Another buyer from classic car LEDs too. My whole front headlights for my FTO and Corvette are from them.
Good call on the dual white / indicator LED for the 68 Ross. I didn't notice that before. I might have to look. I also have a complete LED setup at the rear, was done on import, so only got a few lights here and there that aren't LED.
I had been a little concerned about use of the 68's back-up lights as indicators (being as they are a fair distance from the lateral edge of the car) and whether another driver would be confused?......but I really think that if the colour is correct and bright enough there shouldn't be an issue. Haven't looked at 'construction and use' regs (and I won't) to see if the back-up lights fall within spacing/height regs. Our other alternative is to retro-fit a later pair of C3 rear lights.......but that would remove the 'unique' '68 only feature of having 4 stop/tail lamps wouln't it Capt?
To be fair, when I said about complete LED setup at the rear, I meant the four main ones. To be honest I can't remember now which light does what now. I'll have to have a look next time I'm out in the Vette.
