My car is fitted with headers and I need to overhaul my '71 starter motor. It won't come out with the header in place so I've removed it. It was very untidily wrapped in white glassfibre tape....
...which I removed with the intention of replacing it more neatly with titanium tape. However, removing the wrap revealed a lot of surface rust and a fair sized hole burnt through one of the pipes.....
The surrounding metal was very thin but my local exhaust guru made a good job of welding a repair 'scab'.....
Given the poor condition of the metalwork I'm wondering if wrapping is a good idea. My starter problem is not associated with heat soak, although the collector passes very close so maybe just wrap that part and give the rest a coat of VHT?
What's your opinion - wrap or not wrap?
