In doing a compare of a pure GM calibration you obtained and your latest tune with those DTCs off
I am not thrilled in what parameters were changed and what values were used
Compare shows on right what changes are
I suggest you at least get done what is needed in scanner testrun to determine if you're ready to go get tested and check again before going that the I/M ON_BOARD tests are in a complete state
Compare shows this tables and values changed in your tune versus GM stock calibration
After your county/state ? Is passed, then I suggest you get like one long scanner recording testrun and clean the tune up
| Name | Description |
| VE Initial Correction Factor | Initial value of the VE correction factor, the ratio of the MAF airmass to the VE airmass. |
| Power Enrich Delay RPM | PE mode is delayed if RPM is below this value. |
| Power Enrich EQ Ratio | This is the main table that is used to tune WOT fuel. The values in this table are Fuel/Air multipliers (or Equivalence Ratio) ie. values greater than 1 are richer, values less than one are leaner. The values relate directly to the Stoich AFR and the resulting commanded AFR is Stoich divided by this PE multiplier. Eg. if the multiplier is 1.1 then the commanded AFR will be 14.7/1.1 or 13.36. |
| Catalyst Over-Temp Enable | Master enable/disable for catalyst over temperature protection. |
| Main Spark vs. Airmass vs. RPM Open Throttle, High Octane | This is the High Octane spark advance versus RPM and Cylinder Airmass. |
| Main Spark vs. Airmass vs. RPM Open Throttle, Low Octane | This is the Low Octane spark advance versus RPM and Cylinder Airmass. |
| IAT Spark Advance Correction - Add | This table is used to modify spark advance based on inlet air temperature. It adds to the current spark advance. |
| IAT Spark Advance Correction 2 | This table is used to modify spark advance based on inlet air temperature. |
| IAT Spark Advance Correction - Mult | The multiplier is used to proportionally enable or disable this feature. |
| ECT Spark Advance Correction - Add | This table is used to modify spark advance based on engine coolant temperature. It adds to the current spark advance. |
| Knock Sensor Threshold Init | Initial learned threshold for knock detection. If knock sensor exceeds this learned value then the engine is considered knocking.. |
| Knock Sensor Threshold Min | Minimum learned threshold for knock detection. If knock sensor exceeds this learned value then the engine is considered knocking.. |
| Master DTC List | Tampering with emissions control devices can be illegal. Please check your local laws as well as EPA rules and regulations for legal modification. Disabling emissions controls should be used on off road use only vehicles. It is illegal to modify diagnostic test results in order to pass emissions testing. FOR OFF ROAD USE ONLY! |
| Shift Speed vs. TPS vs. Shift - Normal | Normal Mode Shift Speeds. |
| Shift Speed vs. %TPS - Normal 6th | Normal Mode Shift Speeds 6th Gear. |
| Shift Speed vs. TPS vs. Shift - Pattern B | Pattern B Mode Shift Speeds, selector in Drive. |
| Shift Speed vs. %TPS vs. Shift - Pattern B 6th | Pattern B Mode Shift Speeds, selector in Drive, 6th gear. |
| WOT Shift Speed vs. Shift - Normal | Normal Mode WOT Shift Speeds. |
| WOT Shift Speed - Pattern B | Pattern B Mode WOT Shift Speed. |
| Base Shift Pressure 5-4 | The base line pressure (main line feed pressure solenoid) during a shift. |
| Shift Time Input Torque Adder PD 4-2 | Adds to desired shift time for 4-2 shift based on input torque and turbine RPM. |
| TCC Apply/Release Speed vs. TPS vs. Gear - Pattern B | Pattern B Mode TCC Apply/Release Speeds. |
| Tip-In TqMgt Method - Garage Shift | Torque management method for Tip-In control torque reduction on garage shifts. |
