Steven Smith
I am currently in the process of reinstating the air-conditioning in my 1986 C4 and on the electrical side, one of the things I need to achieve is the ability for the ECM to turn on the radiator fan when the AC is turned on.
Because I bypassed the original fan control relay to fit an adjustable thermostat that didn't happen.
After studying the wiring schematics I have a simple solution that also has added benefits.
I reinstated the original fan control relay and tested its function, the fan came on at 225°F as it's designed to and also when the AC is turned on, so far so good.
The fan control relay has four wires going to it, red is a permanent live via a fusible link from the battery, black/pink is the feed to the fan, dark blue is a fused, switched positive from the ignition and dark green/white is a switched negative from the ECM.
The ECM controls the fan by applying a negative to the dark green/white wire, whenever it wants to turn the fan on, this energises the coil in the relay which then supplies the positive feed for the fan to turn on.
It is the dark green/white wire we need to modify as this controls the whole circuit.
I cut this wire and added a "piggyback" connector then reconnected it back to the relay.
The adjustable thermostat has two connections, you run one to a negative chassis point and the other to the "piggyback" connector.
With this wiring configuration the adjustable thermostat will supply a negative feed to the fan control relay at the temperature you set it, and the fan will turn on.
When the AC is switched on, the ECM will supply a negative to the fan control relay and the fan will turn on.
This has two benefits, the fan will switch off when the ignition is turned off because the relay coil will lose its positive feed, and most importantly of all, if the adjustable thermostat should fail the ECM will still turn the fan on at 225°F as it was originally designed too.
