Hi all, after realising that my wiper cowl. And headlamps are Not Actually supposed to open and close once every time the engine is started, I am in the process of trying to find a leak or faulty component. Perhaps someone here may have had similar symptoms and have an idea where to look.
I have as well as the opening and closing on start up, passenger side hlamp is slow to open and close.
If i pull down the headlamp over ride under the column the head lamps open but the wiper door opens as well.
If I pull down the wiper door over ride under the column just the wiper door opens.
If I pull out the headlight switch, the headlights And the wiper door open!
I disconnected the 3 lines to the vacuum storage tank and connected them together to by pass the tank but that made the headamps and wiper door open and close randomly and repeatedly!! So I reconnected the tank back to normal. The 72 had all new lines when rebuilt and all still look as new . Got to download some info to study but any suggestions as to where to start would be appreciated. I have checked filter and check valve and think they are good., I am guessing it is possibly an issue in a part of the system that affects bothe wiper door and headlamps ? TiA
