CrispyCleen
So, I have a ‘70 that (in the engine bay) has seen better days. One of the previous owners replaced the engine and gearbox to a ZZ4 and T400 auto box with a spoon and one hand. Even then, I think they weren’t sure how a spoon worked.
Among the other delights I have had to set right, I trying to get the windscreen washer system to work again, and I’m pretty sure this has never had one. Let me explain, the heating system inside has been disconnected from the coolant system (I’m assuming at this point it leaks). The coolant header tank has been replaced with a plastic (generic) header tank from somewhere. This has been fitted in the location I thought the washer tank would have fitted based on the replacement I ordered. However, since trying to fit it and scratching my head for a while, I got my build manual out and trawled through the drawings to see where the tank would have gone, only to find that it should actually be the bag type.
”oh ok, thats mildly annoying, but at least I know now” I said. So I go looking for the mounting hooks under the drivers side wing panel to check if I was correct. But no hooks. Not even holes where the hooks would have been mounted.
so, where the heck did they mount the washer bottle? Did they mount a washer bottle? Was windscreen washers an option?
i have a theory, which I am mentally blocking myself from thinking as the implications are pretty daunting.
also, does anyone want to buy a NIB washer tank?
