Last triumph
Need to get under the front of my '81 using a jack and then jack stands.
No problem of where to put the jack stands once up in the air, but from what I've read on the net, I get the impression that jacking the front up from just one side could induce unwanted torsional stress to the frame and body??
If so, the cross member looks to be a sensible bet, other than the damage this can cause.
What is prescribed method of lifting the entire front in a safe, non-damaging way - jack only, no ramps or lift.
Thanks.
Thanks.
