trevbeadle
Hi,
could someone please upload a photo taken from under the front wheel arches showing the panel/insert that fills or partially fills the 'hole' between the wheel arch and the engine bay?? Both sides of my /79? are missing and there must be a great deal of crud that gets into the engine bay especially when wet. If I can get an idea of shape/depth/dimensions I'm sure I can fashion something from either rubber sheet or plastic. I'm sure its only held in position with plastic push rivets'/firtrees' or similar. Photo
 attached.....its the arched aperture above the top wishbone of the front suspension.
Thanks
 attached.....its the arched aperture above the top wishbone of the front suspension.Thanks
