Dazaa - going back to 'basics' - you've installed a Holley Sniper injection system, yes?. Presumably you've got a new high pressure electric fuel pump 'feeding' it? (or perhaps a 'sump' system?) - are you able to re-install the original carb set-up (whatever that was, Hollley or Rochester) and 'theoretically' get the engine running 'old school'?
Also is the inlet manifold correct for your set up ? Any idea what compression ratio your block / cam should be . I know you said that compression was low across all cylinders .
Hi Dazaa
You could drop in a crate engine, but if you’re swapping over the fuel and ignition systems......I would worry it might run exactly the same. Bad running engines are usually fuel or ignition issues. Are you sure there’s not a big air leak somewhere? Is the Pcv valve plumbed up correctly.
I’ve heard that EFI are very voltage sensitive and will play-up if the battery or alternator are iffy.
I am no expert on these matters but very low compression heads mated with a big cam sounds a bit of a mish mash to me . I am sure someone out there will have an opinion on this . Any idea how low very low compression is ?All I know is that it's a 70's truck block with really low compression heads that the previous owner stuck an edelbrock performer intake and a big cam in. No other info, when it runs the idle is really lopey, compression test was 120-130 across all cylinders, when I first removed the valve covers I found 2 rocker arms totally loose and set the valve lash correctly. After that it idled ok but still felt like it had a slight misfire and absolutely no power when I drove it, my k10 pickup will throw me back in the seat under acceleration, this couldn't even break the tires loose at wot
Even on an engine with 9.5 to 10.5 c/r a poorly selected cam will effectively reduce dynamic c/r significantly. Truck or mid 70's stock engine could have a c/r of 8 or even lower. Cam manufacturers can provide cams that are optimised for vehicles with low c/r's and get reasonable performance. My inclination (depending on your budget) would be to source a 'bare' crate engine and utilise much of the stuff already purchased.........perhaps a 383 stroker would give you the oooph you are missing? - look at Roadcraft's website?
RoadCraft – UK Ltd
roadcraftuk.co.uk
