phn
Hi there, I joined CCC a few days ago as I'm looking for a C5. I did test drive a very nice one today however it had a couple of strange issues:
1.) The climate control temperature display initially had no set temperature display at all (only the fan speed) but then after a few minutes the set temperature numbers flickered into life and it was fine after this? Is this a sign of the climate control display being on the way out, and is this a costly fix?
2.) The headlights only popped up and illuminated approx 1 in every 4 times that you twisted the stalk to the on position. It was weird - occasionally it worked fine, but most of the time not. I was wondering if this is a dodgy stalk or is there some special procedure I am unaware of to get the headlights to work? (When they did pop up they both worked quickly with no unusual noises).
Finally the car was on standard wheels front and rear but probably needs new tyres. What would be the approx cost of a replacement set of good quality tyres?
Many thanks!
Many thanks!
