Krusty
Can't thank you all enough for the support so far!
I have been taking the advice.
I am going to my friends in it tonight which is 23 miles each way and it has a mix of A roads, B roads and 2 major towns. So it should be good by the tine I get home I imagine
I've also used the silicone spray on all the rubber boot seals and so on that you pointed out. So more updates on that later...
Next on the list, this oil leak!
So whilst fiddling around, the engine has been basically running on and off over the last 2 hours on the driveway and I spotted a very thin stream of oil running like this
Again, I have checked the rocker cover seal for leaks but they're bone dry!
What else is up here that could cause an oil leak?
Cheers
Cheers
