Fatbloke-Dim
I have an SLP ZL 465 kit fitted to my '06. The rocker arm bearings are not ageing too gracefully .The issue now, not surprisingly, is that info on these parts is pretty well non-existent. The rockers are 1.85 ratio . What I'm trying to find out, is whether the roller bearings are the same outer diameter as stock rockers. If so , this allows me several replacement/upgrade options , I would rather keep everything as installed with the kit, as going back to stock may be opening another can or worms. I've eaten enough worms lately ! If I can find out the size of these bearings without having to pull a rocker and dismembering it to measure, that would be just great . Now don't y'zll get upset if I ask if metric measurements are available, that's easier, but I do still work in old money / inches !!
Thanks so much for any pointers on this one, it's been a bit of a saga..........
