Clarkys Corvette C5
In the USA those lights are required so as example you can see them on my 1999 C5 as you see below
Maybe some odd law in the UK that require them not to be on the car ?
Clarky
We have a lot of odd laws here....no donkeys in the bath after 7pm etc. @teamzr1 ! I'll just be happy to be able to give a friendly flash of the lights as I need it
You mean this ?
The multifunction lever on the left-hand side of the steering column includes your:
_ Turn Signal and Lane Change Control
_ Headlamp High/Low-Beam Changer
_ Cruise Control
_ Headlamps Switch
_ Flash-to-Pass
To signal a lane change, just raise or lower the lever until the arrow starts to flash. Hold it there until you
complete your lane change. The lever will return by itself when you release it.
Flash-to-Pass
With headlights ON momentarily, pull the turn signal lever toward you.
The high-beam indicator will flash to indicate to the other driver that you intend to pass.
If the low-beam headlamps are off, and you have the optional fog lamps on, the fog lamps will flash.
I stand corrected
What was mandated is the daylight running lights having come on after startup
Fog lights were an option :
T96 - LAMP, FRONT FOG
Clarky
@teamzr1 I live in a small village and we have roads not designed for a stonking Corvette going one way and a bus going the other and my gut instinct is to give a little flash to the bus to say " yeah, you go and I'll back up and pull in" ....its amazing how I can say so much through a light flashing. Its like morse code only I know nothing of morse code! I can also hammer out " you may cross the road and I won't kill you in the process" and other classics like " thank you for letting me go and you not smashing my beautiful car" and even " hey, there is a police car by the side of the road checking for speeding cars and bikes so slow down"
Have you tried the flash to pass with the headlights on ?
Is the FOG switch shown below as on my 1999 C5, on yours by the hatch switch ?
If so,here is the wiring connector for the fog and hatch switches for USA and Export models
Wiring connector for front FOG lights
If C5 was built for export only rear FOG lights
Clarky
Flash to pass works with the headlights on, mine is a US model rather than an export model, though I appreciate it wears export tail lights these days. The fog light switch operates the rear fog light ( no idea if that flashes when I use flash to pass! That'll surprise a few folks following me! ) which is another UK/ Europe oddity . I'll be able to check under the bonnet ( hood) in the week.
Since the fog switch exists, rear fogs exist and an American model sounds like a past owner outside the USA took the lights out
Are the round holes where lights go still there or blocked off ?
Check for the 2 wire connectors on each side with black and purple wires
Clarky
The round holes are still there. At some point the car had an induction kit fitted with twin cone filters and I think they were fed to a point by the holes. It's just if and where they have hidden the wiring that troubles me. Sadly the car is at home and I am out in my shitty company car. I'll keep you posted though on my adventures!
OK makes sense now
They were pulling in the outside colder air through the filters for a better charge to the cylinders
where stock filter pulls in hotter engine bay crappy airmass,
Be dumb if they cut those fog wiring connectors off, so look real close of wire loom going to the front lights
Problem with 2 round opposing filters causes air to swirl and air to collide causing turbulence as that effects what
the MAF sensor mounted right after filters reports to the PCM and causing fueling issues
Clarky
I am not a fan of the two cone filters. The previous owner gave it to me in a box and it's currently running a stock panel filter. If the import tax and delivery ever goes back to normal I like the look of the Vararam kits, bit for now it'll stay stock. I want to get it back to a good base line stock car, then we'll go modding! Intake, cams,brakes, suspension, supercharger...the list goes on!
Vararam is crap design and quality
They have even and lawsuits on jink high dollar so-called performance aircleaner boxes
Read what I wrote back in 200 when I did multi tests
Here is the best one I have tested and have been using it for over 22 years on my C5
Donaldson makes this and also make filters for military
I designed and used to sell a cold air box for the Blackwing and it that looks like this
Anyone could make a CAI like this and not worry about issues I mentioned in the other post
or pulling in outside water to lock up the engine
Clarky
I appreciate the heads up @teamzr1 ...I hadn't done an awful lot of research into it but I'll look at the thread. I have always been sceptical of any cold air intake over factory. My theory is that the manufacturer will spend a lot of time and money developing a good compromise of cost vs performance. In my old Mk5 GTI I just swapped over to a ITG panel filter in the stock housing and that was a fair gain, maybe a better panel filter is the key?
Most of the Corvette tax priced so-called performance mods are total crap, not designed, just a con job as to performance gains
As you mention, want a filter with a lot of flat surface as that straightens the airflow
The Donaldson Blackwing as I showed has two flat surfaces
Is washable and only use very light spray of oil after cleaning it
97BlackC5
Nice thread, good to see the little jobs getting done, talking of which where did you order the front & rear badges from and the jacking plugs if you don't mind me asking? Two jobs I really should get done on my C5.
Clarky
Front and rear badges are from GM and were delivered over by family who were visiting the UK and the jacking pucks were from Amazon @97BlackC5 . Bit of a life hack is to set up an amazon.com account as well as a .Co.uk , some times things are cheaper and still have UK delivery on them ...or if you got family or friends in the US get them to take them in and forward on the postage.
