Edelbrock supercharged 1980
Tam
Been working on this car for 6 years now, new blueprint crate engine, wrapped in satin blue, side pipes ,van steel front and rear suspension and so much more along the way.
Always wanted a supercharger and found one albeit was missing alot of parts so had to buy another one.
Found a great classic american specialist near me and they have really helped me bring this car along 😀 shout out to Grumpys garage
Anyway here's the nearly finished project just need some wider rear wheels to help put the traction down
That’s certainly a head-turner!
I keep thinking about side pipes for my car. What make are yours and what inserts/ mufflers did you go for?
Re side pipes, ( something I’ve always loved) I think the 1969 factory one year only version are the ones to go for on a C3. To my eyes they look just right.
Tam
Thanks 😊 Im pretty sure they are dougs got them before the cost of living so were sub 1k nearly double now...
No mufflers so very loud 🙉
Side exhausts can be pretty loud depending on make. Factory C2 and C3 pipes aren’t too bad. More droney on coupes than convertibles. Early Thursh outsiders and sidekicks were about the same noise level. Hookers seemed to be louder to my ears. No idea about all the modern variants.
Problem with all side pipes whether factory or aftermarket is constriction of power output. Less an issue with lo-po engine options than HO options. Muffler inserts for Hooker or Doug's side pipes once again will restrict power output unless considering the least restrictive (and therefore loudest) muffler inserts.
Thing is.........they simply look so good don't they?
  • Like
Reactions: Tam
Going through the paperwork on the red '66 coupe I came across a receipt for the exhaust which is written down as SWEET THUNDER GIVE NO MERCY what the hell I thought.. I googled it and sure enough it's a real thing :oops:
Features/Benefits​
  • We Have Your Side Pipes Covered For Any C2. From Small Block To Big Block, From Super Quiet To The Ones Who Love It Loud, We Have Sweet Thunder's Unmistakable Give No Mercy Sound. With Our Varieties Of Side Pipes, We Can Please Any Ear. Sweet Thunder Makes All The Right Bends In All The Right Places, With Side Pipes That Are Designed To Fit, And Will Sound As Good As Your Car Looks.
  • Aluminized Steel Pipes
  • 2.5" Inner Baffle (Loudest, 6 Db Louder Than Stock)
  • Made For 2" Small Block Chevy Manifolds
  • Now With Easy To Install 2 Piece Design That Allows For Fine Tune Adjustment Of Pipes On Your Car!.
  • We are unable to accept returns on any exhaust system or component that shows evidence of being installed. Installation marks, scratches, or any alteration observed on the product will render it ineligible for a return, credit, or refund. Please carefully inspect and consider your exhaust system choice before installation to ensure it meets your needs and expectations.
