Don't give out advice if you do not know what your talking about outer skin of c5 doors is fibre glass !!!!The outer skin isn't fibreglass, it's plastic. Looks to me and I'm no body man that a small Dremel to get it smoothed out then just build up with a good filler.
C5 Corvette Body Repair - How To Fix '97-'04 Corvette Body Damage - Vette Magazine
We use our 1997 Chevrolet Corvette to show you how to repair the sheet-molded compound (SMC) body panels and bumper-mounting tabs on your C5 Corvette - Vette Magazinewww.motortrend.com
Front fenders and front and rear bumpers are the only bodywork that are plastic on a c5 ,doors quarters bonnet sills are all vaccum bagged fibreglassYou seem to be quite sure about that assuming Custom Exotics is what you do I'll agree that you know more in this field than I ever will..
But. It would seem that plastic is used in C5 (and later models) reducing the fibreglass content to just 20% chopped filler:
C5: Getting Serious About Weight Savings
The introduction of the C5 in 1997 represented one of the rare instances in the automotive world where the next-generation model weighed less than its predecessor. Even more impressive, the '97 Corvette was larger overall--longer and wider--than the '96 model, yet it tipped the scale at about 3,220 pounds with a manual transmission, compared with the '96's 3,300-pound curb weight.
A number of contributors helped drive down the C5's weight, including the use of SMC body panels that had a higher content of plastic than ever before. The material, which is basically the same as used in the C6, was composed of about 40 percent resin--polyester, vinyl ester, styrene, or a blend of all three--33 percent calcium-carbonate filler, 20 percent chopped fiberglass, and the remaining 7 percent resins and hardeners that improve the out-of-mold surface finish.
Source: Corvette Body Materials - - Vette Magazine
The 20% chopped fibreglass is just filler to stiffen the panel. I had two C5's back in the day and in no way is the outer surface the same as my current C2's & C3 which are of course fibreglass..
Repaired loads of these we own 2 c5 and a c6 I think we should know how to repair themThe C5 as Mr Cricket says isn’t fibreglass…
The C5 is sheet moulded composite, it may look like fibreglass as it does have reinforcing fibres. Fibreglass won’t adhere to the SMC…
Is the outer skin on a C5 fiberglass?Repaired loads of these we own 2 c5 and a c6 I think we should know how to repair them
So no then. We could have avoided all this if you'd just agreed it's not fibreglass and mostly plastic All good and hopefully Nick gets his Corvette sortedYes you would do a normal fibreglass repair please feel free to give scott a call on 07915387879 and he will give you the best advice possible to effect a repair
Re-read what the write-up of that URL aboveRepaired loads of these we own 2 c5 and a c6 I think we should know how to repair them
Its not bloody pastic do you know what stick ur Araldite on it better still buy yourself some pickstick and use that I am through trying to give advice to peopleSo no then. We could have avoided all this if you'd just agreed it's not fibreglass and mostly plastic All good and hopefully Nick gets his Corvette sorted
No metal or fibreglass or plastics require different primerSo a question would be
IF doing the repair with only pre-1981 fiberglass makeup,
does not than to assure paint matches and the difference in SMC and just fiberglass surfaces
require different primer ?
Mate you are talking rubbish do you actually think the manufacturer changes the shade of paint to do the bumpers !!!!! Please !!! I have never heard do much rubbish in all my life!Starting with C4s,
do not have external bumpers, but instead urethane fascia that are not per se plastic
Urethane fall into the category of materials called rubber.
But they're not quite rubber, either. Urethane fill the gap between rubber and plastic.
They're harder than rubber, which contributes to their outstanding load-bearing abilities.
So another surface type and requires different primer and paint shade the body has.
