I've got a minor leak from my fuel pump. I think it is coming from the brass fitting that screws into the bottom of the pump. I guess that this is a taper thread, but to tighten it up I'll have to disconnect the pipe that goes up to the carb. If I disconnect that pipe will I empty the contents of my fuel tank onto the garage floor? Also should there be any thread sealant on the taper joint and if so what can I use that won't be dissolved by fuel?
