Hi all, took the vette out for a little run this eve.and noticed that when I turn ignition on there are no oil or charging lamps lit. Door ajar and handbrake lights work, as do indicators , side and headlamps. What dash lights should come on when ignition turned one position? Dhould there be a fuse i need to check or could this be a side effect of my headlamp switch , thermal cutout/ dimmer switch issue i reportedwhere my main beams switch off and on due to overload. Havent had time to sort that yet either. Any advice appreciated.
thank youβs
thank youβs
