Brake pedal can be pumped countless times, but that does not move the old fluid out the ABS pump and its fluid tank volume
Not doing a correct process of using like a OBD-II scanner or a Tech-II sends commands to each wheel's ABS solenoid to open
so the fluid for the wheel being flushed
Not doing so means the first time ABS is commanded ON by the EBTCM, the old fluid is mixing (with the water it may have) with new fluid
If bleeding system and not the ABS
Air in your ABS brake will cause the brake pedal to feel spongy, and the air will have to be compressed before the pressure is applied to the brakes.
Bleeding an ABS module will help to remove the air in the system, making your brake system more responsive.
This is Nick's C5 ABS unit, so can be seen how much older fluid can be in it
As to swapping to braided hoses, many may have been coated and hence when installed to the end fittings may not then have a ground
path that the speed sensors need for ABS and traction control, so lots safer to test to be assured the ground path is these
Stock hoses have a ground braid in them to provide that ground path
