I keep toying with the idea of having mine on a rolling road to find out just what it is turning out . I am running with a 305 cu in Camaro IROC -Z engine with a 9.5 compression ratio , Edelbrock Torker 2 inlet manifold and 600 cfm Edlebrock carb and a Hypertech Street & Strip dizzie . De smogged and tandard manifolds but decatted and piped straight through to Supertrap tail mufflers . Happy with what I have got but just wondering what max bhp to expect .
I assume Brits call a "Rolling Road" is a chassis dyno ?
If so, what do you use, a static drum type or a load bearing type ?
If you want more detail, if you supply me with a dead stop run to like 100 MPH (or at least 10 data points) and tell me
the elapsed seconds from 0 MPH to each 10 MPH after that, along with what the RPMs were for each MPH of each 10 data points
So that is elapsed seconds, RPM & MPH I can do all the math
If you want the numbers even closer than tell me what the weather temps, dew point, pressure, and aprox elevation in feet is, so I can calculate corrected D/A
Also, what you think your flywheel HP is and aprox weight I also calculate what numbers would be at a drag strip as to ET and trap speed
I crunch all the numbers
If wanting more data tell me rearend gear ratio, each tranny gear ratios and tire size
And results are like this at the HP and Tq to what RPMs were that would not get using a static type of chassis dyno
