Steven Smith
As promised a while ago I am now in a position to start my biggest project on the C4 so far, painting it on a budget!
The history of my car is that sometime in it's past it received a very poor respray, no panels or lights were removed and it was done in the wrong colour red.
The correct colour is 81U bright red but it was done in a shade of Subaru red.
Not only is it the wrong colour but it fades terribly in the sun, I can cut and polish it to a lovely finish but within a week it's a milky red again.
I did toy with the idea of wrapping it but couldn't get a red that I liked and the cost wasn't much different than painting it but the biggest disadvantage is that wrapping is temporary.
So a full respray it is, my biggest disadvantage is that the car will not fit in my garage so what can be removed will be painted inside and what I can't remove will be painted under a gazebo!
So this year I have been obtaining everything I need.
I did look serious at electric spray guns which are quite new and look very promising but settled on a conventional compressor powered system as it also allows me to use it for air tools.
My first purchase was a second hand compressor for £100, it has a 3 hp motor, has an output of 14 CFM and a 100 ltr tank.
Air lines, air / water seperator and connectors was another £50.
The next thing I needed was a spray gun, after a lot of research I settled for a Inokraft Drizzle LVLP spray gun at £110.
This is a Low Volume Low Pressure gun and only needs between 9 and 10 CFM to run, but can work as low as 4 cfm.
The Pro kit comes with everything you need, the gun, 3 different size nozzles for different paint consistency, tool kit and cleaning brushes, pressure regulator, air / water seperator and disposable cup system for the paint to make cleaning up easier.
Once assembled the gun looks quite big but it's easy to handle.
A good face mask designed for 2k paint is also essential, I bought a Gerson 2k paint respirator face mask for £36.
My last purchase so far has been paint. I have chosen 2k solid paint rather than base coat and lacquer because I am not using a metallic paint and I think it will be quicker and easier for my situation.
I have gone with MIPA HS 2k paint along with their HS25 normal harden and V25 thinner.
This is a high solid paint so gives good coverage and the HS25 lacquer has a good gloss.
I purchased 5 ltr of paint mixed to 81U bright red, 2.5 ltr of hardener and 1 ltr of thinner. The mix ratio is 2:1 for paint and hardener along with 10 to 15% thinner.
Total cost for the paint was £300.
Just got to buy some cheap thinners to wash the spray gun out before and after use, panel wipe, masking tape and paper and sandpaper.
That's as far as I have got so far, with luck I am hoping to paint the roof panel this weekend, I will post pictures of my progress, success or failure and keep you all posted.
After all, what could possibly go wrong
