Petrol
Bondy
Having just purchased my first Vette which is a 2008 base model coupe with the Z51 package I suddenly wondered what petrol is best. I believe the previous owner just used standard unleaded but would appreciate any advice. Cheers
I'm sure a C5 owner will come on here soon and advise you. Me? (and other earlier Corvette owners) perhaps will often use Tesco's Momentum Super unleaded 99.
Yes, Shell and BP will tell you about their special clean super unleaded fuels.......but they all now have ethanol content (as does Tesco's Momentum 99) - but at least Tesco is generally a little cheaper with a higher octane rating.
Blackzed
The standard unleaded is perfectly good for a C5, only use premium if there has been mods done to it.
Ethanol content is a non issue.
Invetterate
Congrats on your first Vette! Hope you have many happy miles together!!
The car will run fine on standard unleaded as stated, but the ECU can detect higher octane fuel and switches to a different ignition/fuelling map. It will thus run better on E5 and if, as suggested, you use Tesco Momentum 99 [which is the highest octane fuel normally available in the UK], it is little more expensive than a big name 95 octane. The additive package for the 99 is also one of the best in the business and is really good at preventing problems liked clogged injectors. It's your car and your money, but I learned a lot of this when my car was remapped by a guy who has been remapping LS engines for the best part of 30 years and have used Tesco 99 ever since.
Bondy
Thanks to you all for your petrol views and as with most things it seems we all have our own choice to make but at least I am now better educated by your responses. Cheers.
Thing is........not all areas in the UK are alike relating to ethanol content in fuel. Some of the major names have, perhaps the full prescribed amount.......others less. If you want to be more specific there are Youtubers who take samples from local filling stations and test for percentage content. It's more of a 'thing' for the older cars really.
Redlevel
Some stations sell E5 from E10 pumps like my mate who runs a local J*T Station and takes what he can get to fill up tanks that are running low.
I asked if that was legal and he said "it's specified as up to E10, not necessarily only E10 itself.
As above E5 and E10 etc doesn't means it has to have exactly 5% or 10% ethanol etc. It means "up to" that amount, but not over the labelled number, meaning it can actually have 0% ethanol in it, and for example E10 can NOT have over 10% ethanol in it. Indeed Esso for a while was selling their E5 labelled petrol with actually 0% ethanol in it. It was quite handy.
If one is really concerned about the content of the fuel being used and not convinced that petrol retailers are being informative of its Ethanol content etc - there is always the option of buying drums of certified Sunoco fuel from Anglo American Oil (Anglo American Oil Company | Motorsport Fuels & Oils UK) in a multitude of leaded and unleaded octane ratings plus 'sustainable'.............but if already unhappy about the current £1-60 to £1-70 and higher pump gas prices........your eyes will water at the typical £100+ price for a 25 litre drum.
For those who like the techie detail
The PCM has two main timing tables
1 is High Octane and other is low octane
When the PCM sees more than 25% of fuel added to the gas tank it
jumps to the HIGH timing table and uses that until knock sensors report engine knock
If enough in series knock occurs the PCM assumes low quality gas or higher amount of Ethanol as
it causes the AFR to be much leaner causing knock
The PCM will pull up to 15 degrees (or when I tune PCM and change knock settings) of timing which kills off torque and horsepower
PCM than stays in low octane timing table until at least 25 % of fuel is added to the tanks
As I show as example a stock 1999 C5 the low and High Octane tables
The PCM calculates how much air/fuel is reported and what the RPMs are at that moment
Notice at 0.48 grms of air/gas at 1,600 RPMs when there was no knock issues it command timings of
24 degrees, but if there were knock jumps down to the low octane timing table and only commands 17 degrees of timing
This people can say it is fine to use lower grade of gas or higher percentage of Ethanol
Yea the PCM adjusts for it but the cost of losing performance until the next fuel is done
To really know how much Ethanol your pumping into the gas tanks is simple
Can buy this like Amazon or even make one
As shown fill water to the blue line
Fill rest with the gas
Mix and let sit a few minutes and then read now where the gas and water meets and what the amount
of Ethanol is in that tank of gas
Dorsetsteve
If I’m not mistaken US fuel has contained higher ethanol than that sold here in the U.K., so it would be logical that US manufactured cars would be less likely to be incompatible with higher ethanol content fuels that have become the European default in recent years.
It’s kind of a relief to drive a car like this and not concern myself with it. My Turbo Jap car that’s now sold could not be run on E10 due to pre ignition risks and the injectors not being suitable, E5 can be a bit hit and miss to find out in the sticks.
I do fill the Vette up with E5 though for various reasons including fuel stability.
You're correct but only for vehicles made later than mid 1990s and newer
But older vehicles like C4 and older have no real control of the ill effects of Ethanol or engine knock
Due to politics and lobbies have made it worse as used to be E10 but couple years ago
forced E15 being allowed and the gas pumps at stations do not even post on the pumps
the percentage of Ethanol being pumped into vehicles gas tanks
Many counties in the USA have mandates of a winter grade and summer grade gas makeup due to Ethanol
causing so much more issues in lower elevations and hot weather than in colder months
Add where vehicle is being used, where at higher elevations the AFR would be richer so lower octane is sold
where near sea-level AFR would be much leaner due to the Ethanol causing a lot more engine knock and less fuel mileage with loss of performance from that
But even at higher elevations less air/density with Ethanol also than outputs less HP/Tq
Those wanting best performance or for racing reasons :
Starting with the C5s the PCM has built-in adaptive strategy which learns and adapts to fuel type, elevation, weather and drivers style of driving
Say living at like 3,000 feet above sea-level and / or cooler weather the PCM adapts and adjusts for that
You go to a drag strip or other track racing for a day of racing and the Corvette suddenly runs like crap
The drag strip though is at sea-level and hotter weather but the PCM had learned for where you live so it is still commanding engine as being there when it has not learned for the strips location and weather
The lower the elevation is the higher the octane is sold and higher elevation lower octane is sold
Worse is the first couple of runs and the engine is sluggish and your ETs and trap speed are crap
That would be because PCM not having relearned and Ethanol causing engine knock so as mentioned
above the PCM is forced into low octane timing table along with PCM reducing more timing due to knock and now all strip runs will be with less HP/Tq
Good idea then is drive to the track location, buy higher octane gas there so PCM using the high octane timing table to reduce chance of knock and then drive maybe like 10–15 miles mixing up RPMs and engine loads for PCM to learn those conditions
Of course using an OBD2 scanner would allow seeing if and how much engine knock there is and if the timing looks like PCM is using the high octane table and if need be reset and clear fuel trims
Out of interest, how does the PCM detect the fuel? I'm guessing it just uses the fuel level sensor to see if fuel tank is greater than 25% full?
I was looking in some depth at Anglo Americans website yesterday - the range of fuels available, both leaded, unleaded and sustainable is amazing (all fuels however are equally 'eye-watering' in terms of price!)
On the note of 'eye-watering' I spent an hour or so last night watching 1320video (https://www.youtube.com/@1320video) and their coverage of the bi-annual 'War in the Woods' minimalist 'no prep' drag racing.
see (
Guessing there are zero restrictions on types of fuel used - some racers are obviously using a nitromethane/petrol mix as 1320's presenter had issues with watering eyes at times. Manic racing.
Correct,
Uses the float sensors in both 9 gallon fuel tanks
The PCM's Calibration monitors and does the math as to fuel tanks gas levels
Nice one thanks. I wonder why 25% was picked for the cut off? Seems a little odd as sometimes you like to ride around with less fuel in for less weight, so you'd think the car would be quicker. But if its changing its tune at lower fuel levels then that ruins that.
Also as to less than 25% gas in fuel tanks
The lower the gas leve lin tanks is the less of submerged fuel pump is getting cooled by the gas
Due to Ethanol attracting water which is heaver than the gas if running on 1/4 tank or less will chance of pump sucking up the water to the fuel system
Also, the PCM is designed when gas level is less than 25% in tank is it de-tunes how it commands fuel injectors and timing to help better fuel mileage to make it to a gas station or home before running out of gas.
Those not having seen C5 and newer Corvettes which has 2 gas tanks connected by a transfer tube with duel pumps and sender floats
