Recurrent misfiring problem
For more than a year now I’ve been experiencing an infrequent and so far undiagnosed, misfire. The engine is a 1971 stock (as far as I know) base 350/270 sbc of unknown mileage. It has points ignition, professionally rebuilt stock Quadrajet carb and headers. The car always fires up on the button and with everything on song, performs very well. Just occasionally it starts up with at least one cylinder misfiring or not firing at all. The first time this happened #5 was the culprit and after fiddling around with changed plug, HT lead and anything else I could think of, it seemed cured. A few weeks later it recurred, this time with #7 joining as a non-combatant. This immediately implied an electrical problem; not only are cylinders 5 and 7 adjacent on the engine, they’re adjacent in firing order. As well as verifying the resistance of the HT leads and plugs, I checked the obvious possibilities of cross firing between leads and tracking in the distributor cap but found nothing conclusive and sure enough the next time it was started, all cylinders were firing again. The misfire recurred infrequently over the next few months so in desperation I changed all the HT leads, the spark plugs, the coil, the distributor cap, points (though not the condenser) and rotor; one change at a time to see which, if any, had a curative effect – none did.
So, after the most recent recurrence, with my timing lamp showing both #5 and #7 not firing at all. I removed one plug at a time, rested it on the block with the HT lead connected and after fitting a spare plug in the vacated cylinder, fired it up. All plugs fired perfectly in fresh air. Even though they were firing in the open, perhaps I didn’t have a strong enough spark to always fire under compression, so I disconnected the plugs and connected an adjustable spark tester between the HT lead and earth. All leads produced a healthy spark at a 10mm gap, so the HT voltage should be more than adequate.
After this last testing, on firing up again with #5 and #7 still not firing, they were joined by an intermittent misfire on #3. Aha! 3,5 and 7 are all on the LH bank; perhaps I don’t have an electrical problem, perhaps I have a head gasket problem? I’ve done satisfactory compression tests on the engine in the past but I repeated it again today – results below. Compression still seems pretty much on point.
I’m running out of ideas now, with the only obvious possible problem left being fuel. If no fuel is getting to a cylinder, the spark plug would still fire so that’s not the problem. If too much fuel is getting there, it probably wouldn’t. The only thing I can think of that would cause unregulated fuel to enter cylinders on the same bank is if the intake manifold gasket was failing on that side, although why this would be intermittent I don’t know.:unsure: There’s no way to check this without removing the manifold, so before I start draining coolant and removing the distributor, carb and vacuum lines, does anyone have any other logical suggestions for causes of my problem?
Have you tried spraying some form of liquid all around the carb and inlet manifold to see if it gets drawn in the the engine, indicating a vacuum leak?
All V8 engines from the period with old school carburetion will experience often significant variations in the amount of intake charge received.....and there are specific cylinders on a SBC engine that suffer accordingly.
No, I haven't tried this yet Rosco. While an intake leak could certainly weaken the mixture to the point where the charge would fail to ignite - a misfire - I'm not sure why the plug would fail to fire, which my timing lamp is showing what's happening? Still, worth trying before I strip down the manifold.
I had exactly the same issue with my 427 engine. This took me about 9 months to find. It was not long after I'd installed an MSD ignition system and quality 8mm plug leads. It would idle fine. It would cruise fine. Holly DP I'd installed was fine and jetted correctly. It was an irritating misfire on to 7 cylinders on low end acceleration.......and most likely higher end too. Like you I tried everything and checked everything out....all to no avail. For some reason I (don't remember why) I removed the hood and unconnected to the issue chose to drive around the block in the evening.......the root cause was instantly visible at night. This was only under a driven load - didn't do it just revving when stationary. On the BBC engine one of the spark plugs was quite close to the header flange.....close enough to burn unseen through the underside of a spark plug boot. On idle and cruise with minimal load on the engine......no issue. Accelerate and the increased demand with the accelerator pump assisted rich mixture was enough for the spark to jump from the underside of the spark plug boot to the header flange..... effectively 'robbing' that particular cylinder of most of its spark as it 'jumped' to earth on the header flange. Basic electrical characteristics will always see an electrical current take the easiest path. Add a MSD ignition to an engine with it 5 fold (or whatever it is over stock) and the increased increased electrical energy is fully capable of jumping a 1/2" gap (which is what it was doing from the underside of the burn damaged plug boot. On idle and minimal demand cruise both the plug and the earth to flange 'jump' were sharing the spark. Slightest gas pedal demand saw the spark to the plug diminish at best/total loss when accelerating.
Perhaps not your issue but worth exploring.
As you say Rosco, probably not my problem but an interesting possibility. I'm going to pull the manifold; if a failed gasket is my problem then it can be sorted, if not then it's one more thing to cross of the list and if I had a vacuum leak at the carb then that will be sorted too. Stripping things down in the engine bay is not much fun in this weather. 🥵 Hopefully by the time I come to put it all back together it'll be a bit cooler.
