screen washer question
purple charlie
now its warmer back to working on the car.
my previous electrical gremlins are getting better after replacing fuses, maybe corrosion or tired despite being ok.
but the screen washer is still a problem,
wipers working on positions and sliding to the washer position, they pass over, but the washer motor is not working, its had an after market "Land Rover" style washer motor fitted
and Ive also got a new original style one but these do not work. Cant see its a fuse problem or switch as wipers work from same fuse and switch. Haynes manual wiring seems to say feed comes from wipe park relay, could it be this and where can I find the relay to check?
EDIT: looking on Charm, is this the washer/wiper module?
presumably, to remove the washer bottle, you have to remove the inner wheel arch liner as side two bolts removed bottle still held in place.
purple charlie
update.
first picture of top connector on wiper motor, plug only has black wire in centre position. second picture I presume are the other two wires, these have been joined with a mini fuse!! can someone tell me pink and brown , which wire goes to which side??
thanks
for further information, if you need to replace the washer motor, the leaflet included with the new oem style pump says grasp and pull the pump out, and push in on reassembly. What they dont tell you is inside there is a nut with a filter on. this can be undone with a deep spark plug socket, so unscrew dont try to pull out
Someone bypassed the wiper motor module
WW motor has 3 wiring pin connector
Pin A, is pink wire, that is getting 12 volts from the controller
Pin B, comes from ground
Find that controller and when washer is turned on using a volt meter should show 12 volts on pin C, pink wire
If so than check pink wire from controller to pin A of washer connector
Here I pieced together the total wiring for washer/wipers
Print this out as easier to read/follow
purple charlie
thanks JR
washer pump fed direct from battery so know that works, the wiper and washer relays swapped, no difference. the switch seems wo work correct
i have heard the circuit board in the wiper motor suffers from dry joints so that might be next
purple charlie
we both have experience soldering so will give that a try first. otherwise, according to charm will have to see which model of motor its got fitted.
I would suspect being located off the firewall, near the drain for windshield water and the high heat of engine bay
that solder joints inside the unit all those years may have cracked and maybe lucky reflowing solder fixes the problem
Looks easy to take the circuit board off the case and check the other side for issues
purple charlie
Had the motor put today, re soldered 3 dry joints and re wired plug that had fuse across. Still no washers although wipers still do what supposed to. May have to look at a spare motor. Reluctant to remove circuit board as only held in by melted plastic location posts.
