No vents Capt. There should be two tiny drain holes for removing that water build-up. If a genuine genuine big blocl LT1 hood the underside will be smooth from the factory build. If aftermarket It'll have the matting showing.I have a slightly raised hood on mine, but I can never remember which hood is which. So I Googled it just now, and yes, I believe I have an LT1 hood on my Vette. Gives a little bit more height, and looks interesting. Out of interest, is a LT1 hood supposed to have vents in the bit that dips down towards the front of it? Mine doesn't appear to have any vents / anything to allow the air to come up there. It means when it rains I get a couple of small swimming pools at the front of the bonnet.... though I do avoid leaving / using the car in the rain
Looks badass on yours!I have one of these on mine (L88 style) - essential in fact unless I wanted to carve a big hole in the hood for carb and air filter clearance - OK, so mines a big block but only using a single quad Edelbrock Performer RPM - AND - I had to use a thinner air filter element. A small block will be less critical in terms of height and a stock big block LT1 hood should be fine........
Nice one thanks. Shame they aren't vents, but hey, I like the look of it anyway. I'll have to have a look underneath at some point to see if I can spot what you mean. From memory, it looks smooth, but then I don't know exactly what I'm looking for. I suspect its aftermarket though, as my car is a base 327/300hp model.No vents Capt. There should be two tiny drain holes for removing that water build-up. If a genuine genuine big blocl LT1 hood the underside will be smooth from the factory build. If aftermarket It'll have the matting showing.
Fake like the trans am hood and pretty much all others of that era.Nice one thanks. Shame they aren't vents, but hey, I like the look of it anyway. I'll have to have a look underneath at some point to see if I can spot what you mean. From memory, it looks smooth, but then I don't know exactly what I'm looking for. I suspect its aftermarket though, as my car is a base 327/300hp model.
Stock GM 'glass panels, hoods etc are pressure moulded. The underside of the panel is relatively smooth. Aftermarket panels are generally 'laid-up' - so, built-up from layers of glass fibre matting and resin (much mile a TVR, Lotus or Reliant would have been back in the day - GM's panels will be significantly thicker and more durable). Nothing wrong with that - you'll simply see the 'weave' of the matting on the reverse surface of the panel.Nice one thanks. Shame they aren't vents, but hey, I like the look of it anyway. I'll have to have a look underneath at some point to see if I can spot what you mean. From memory, it looks smooth, but then I don't know exactly what I'm looking for. I suspect its aftermarket though, as my car is a base 327/300hp model.
Any part that can be positively date linked/matched to rare/earlier cars is worth additional money to the factory line sticker and chalk/crayon mark brigade.$1000 yes , tens of thouands ... better be careful where I park. I didn't know they were in that league - interesting- thanks
