TimP
Having got a working exhaust all sorted out and tidied up a few other areas there was no excuse for not trying to drive the car out of the garage. So, heart in mouth, started her up, engaged first and let out the clutch......
it's only 4 or 5 yards but its taken nearly 7 years to get to the end of the drive under its own power.
I'll take the SORN off and insure it for the road when it's due for renewal in a couple of weeks. A few other jobs to do until then but feeling highly motivated to get them all done asap.
Wow Tim! Well done , she starts and drives👍brilliant news , 👏ready for early summer
rubyragtop
Great to see that she is able to move under her own steam Tim. You must be feeling such a great sense of achievement bringing her back from near death.
I hope that we get to see her at one of Sussex's events during this year once you have her legally on the road.
TimP
Doesn't time fly - my last post on this was in April when I rashly said that it should be down hill (in a positive way) from here on in. It hasn't really turned out that way - who'd have believed it. So what's stopping things? Weather, life (mostly good things - not complaining) and a few things I hadn't expected in finishing off the Corvette which you think will take 5 mins but end up taking 5 days, or thereabouts. Here are a few examples:
The rear number plate light. For some reason the two holes that hold the number plate light on the inside of the rear fibreglass were the wrong distance apart so that the rear number plate light assembly couldn't be fastened properly. (sorry forgot to take the before photo). Thus the glass fibre had to be extended on the left hand side by about 30 mm to allow a new hole to be drilled. I can't quite work this out as this is definitely the lamp that came off the car so theoretically it should have gone straight on.
With the number plate on and the plate light fitted it all looks a bit more secure.
We won't talk about the paint drips .......
Secondly, the polished stainless steel T-Top pressing. This pressing is held on by a number of screws that fix it firmly to the birdcage. There are two screws that fix in to the upper windscreen surround. On my car this is a new pattern part because the original was unusable. It's probably a bit difficult to gauge from the picture but the lower (plated) bracket sits precisely in the right place to match up with the hole in the pressing. However, having fixed the equivalent plated bracket for the drivers side it was found to be about 8 mm too close to the middle of the car.
Thus the rivets had to be drilled out, the bracket removed, the holes welded up, new holes drilled in the right place and then painted. This was done but (I'm going to blame the 32C heat) I actually managed to drill the new holes in exactly the same place as they were before despite have marked out the new location fairly carefully. Doh! or words to that effect. Repeating the exercise a second time gave the (correct) result. You can just see the new holes in the upper half of the picture. This also resulted in a correctly fitting (but as yet unpolished) pressing.
Just as an aside I have used Rustbuster EM134 epoxy paint to cover the birdcage - a product I really like working with. I think it was recommended to me by someone on this forum - sorry, can't remember who but thanks for the tip. It had a new formulation a while back (with a different mix ratio) and you can see that the revised paint is now much more satin/gloss rather than the original matt.
Between working on these two items I tried valiantly to fit the front bumpers and associated hardware but could not make it work at all with many inconsistencies found. Much frustration, cursing and swearing all round. It took me a depressing amount of time (weeks) to realise that the body was not quite straight on the chassis and needed to be moved over to the drivers side by about 5mm. Thus all connections between body and chassis (mainly the body mounts and radiator support) were removed or loosened allowing the body to be gently rocked into the correct position. I'm not sure if I hadn't aligned it all properly when I replaced the body or it shifted a bit after that because I did not torque down the body mounts until quite recently. I don't know but it seems a lot better now and the front bumper over rider brackets that attach to the bottom of the front crossmember now fit correctly - which is a good sign. One of the problems of doing such an extensive rebuild such as this where just about everything has been undone, repaired and put back together is that getting a good datum point is really quite hard, especially with a glass fibre body with lots of curves. However, I ultimately used the holes drilled in the birdcage sills that align with similar holes in the chassis to make sure that everything was finally in the right place. I'm pretty sure that these holes were placed for this reason and very useful they were too.
Finally (with some good news) I then took the complete rear end apart and sanded down the entire rear end of the body, from door lock panels to the rear valance with a 360 grit paper. I had put a white primer epoxy coating on the body to protect it during the rebuild - it has done its job really well. However there were a number of blemishes to be filled and profiled. This was done - I probably make it sound quick but it took weeks to get everything right - and then a coat of white primer and a very thin white gloss paint were applied to give an idea of how it's all going to look.
With some new Corvette letters and a burglar alarm lock from Eurovettes (thanks Keith!) it all looks quite smart although nothing is fully tightened up yet. The rear lights are my 'test' set - I have a good set for when the paint has been done. The bumpers will need re-plating at some point but that will be for another day. Just an electric aerial and the exhaust embellishers to fit and the rear end is pretty well done. Except final paint of course.
Next steps are the front end reassembly and fitting the interior, starting with the three compartments.
View attachment 33388View attachment 33389
View attachment 33391 View attachment 33392
Wow, a frustrating time by the sounds of things, I can remember a night on my beach buggy build a few years back 2am literally in tears of frustration after doing some job three times !!🤯and still not right. The rear end is looking good Tim, love a white vette. The interior will really bring things to looking near complete. Great work. Can recommend kim in yate , Bristol for the plating, lots on here use him sbs electro platers I think. 👍
TimP
Hi Gary, thanks for the recommendation on the plating - though having had a quick search of platers in Yate I think it is S&T Electroplate. Does that sound familiar? Also thanks for the encouraging words - they really help when your patience is tested by reluctant inanimate objects who don't seem to want to cooperate.
Perhaps I am naive but I had expected that a lot of the bits to be assembled at this stage would be a relatively simple spanner job. May be it's caused by using a mix of new pattern parts and old original parts and rebuilt parts? Another area which will require work are the left and right front grilles which have attachment holes in the grille but not a full complement in the body so either I have to leave one attachment hole without a screw (and it will probably rattle a bit) and doesn't really look good or I spend a few days making some sort of new area to fit a u-clip. Photos from delivery show that previously it had a screw missing. Has anybody else had/seen this problem? See pics for more detail.... you can see one of the lower grille attachment holes but there should be one on the top right hand side too. Both sides are the same.
However, some progress has been made and the weeks trying to get everything to fit seem to be paying off. I can only wonder in awe how anybody puts these front ends together on fresh paint without scratching anything...
S&T Electroplate in Yate are the platers Gary was referring to Tim. They have done my '71 front end........
...and several jobs on other cars over the years. Always impeccable quality and service. Talk to Nigel Hayward.
TimP
Getting the front end sorted has been a bit challenging (to say the least) and I haven't finished it by a long chalk yet. I find that when things get a bit tricky it is sometimes good to do something else for a while and take a break from what's giving you a headache.
With that in mind I turned my attention to the rear compartment frame, which I had spent a little time on a few years (crikey - that long) ago but had put to one side whilst I waited for parts.
When removed from the car the frame was damaged in a few areas requiring a little surgery, two of the compartment doors had detached themselves from the hinges as the wood/composite material had rotted and the hinges had rusted.
One of the doors was just about serviceable with a bit of TLC but the other two were scrap so two new doors were made from plywood of the right thickness. The frame was repaired and painted, new rubber bumpers were fitted, and new hardware was purchased and fitted where necessary, although I have temporarily mislaid one of the locks and two of the cups that surround the lock mechanism. I know I have them somewhere ..... Self-adhesive foam tape was obtained from eBay and stuck to the door apertures. New carpet was obtained (thanks Keith at Eurovette's once again), cut to size and fitted with a spray glue to stop it bagging. I've lost the stickers from the rear of the doors but there wasn't much I could do about that - they are probably available somewhere.
Now, suitably dosed with paracetamol, it's back to the front end....
Looks really good, and I ought to do something similar with my doors as one doesn't hinge any more - just lifts off. Out of interest, how do you lift up the doors with yours? I ask because my 68 has a little handle where the release buttons are to allow you to hinge the door upwards. I can't see how you'd lift your doors up?
TimP
Thanks! You are absolutely right though - I haven't fitted the hoops that are used to lift up the doors. The holes are there for them but the old ones are in poor shape and would let the side down a bit (although looking at them now it's possible that a really good clean would be enough). I'm looking for a suitable red vinyl to make some new ones - shouldn't take long with a sewing machine once I have found the right material.
On your doors are the lock cups/surrounds base metal or colour coded?
If you want to save yourself the hassle, replacement lift hoops are available - at a price. The door lock escutcheons are painted.
I don't have leather (?) hoops like that - all of mine have a curved metal tab that sticks out from the base that forms a handle that you can grab (top of the photo is just behind the seat, with the handle part pointing towards the rear of the car):
My '68 is the same as your Capt. TBA in all the years I've owned mine there hasn't been any piano hinges on the doors - the doors (which seem to be a compressed thick hardboard material) are certainly original, and the handles are as yours. It had had been re-carpeted at some point well before I bought it (including the compartment doors).
TimP
That's interesting - looks like one of the many detail changes GM made between model years.
AI tells me that the metal lift tab is correct for '68 to early '69 cars. The vinyl hoops were fitted from late '69 to '82 (my '71 has the hoops) although there was some rearrangement of the door layout from '78. Since the pulls are interchangeable over the range I suspect many non-original set-ups have ocurred over the years.
The metal 'tags' (to open doors) I find irritating if you are carrying items like toolboxes and containers in the rear of the car - they tend to catch the boxes. 'T' Tops in their stowage bag are generally OK as they sit to the rear of the compartment and being heavy (and not slippery) don't move about too much.......leaving space for toolboxes. However the 'boxes will sit on the 'tags' and potentially rip them out.
Maybe that's why they were changed from metal tabs to leather hoops? As then you can store stuff on them better? For me its a non issue as I rarely ever have anything back there and when I do the tabs haven't bothered me.
Interesting to know about yet another 68 (and early 69) difference to the later models.
Daniel B
I have a 72 with the leather hoops. Mine were all disintegrated so I got a cheap replacement leather handbag strap from Amazon and recreated them.
I was pleased how they came out and it was pretty inexpensive.
