Clarkys Corvette C5
Invetterate
By the way, if your car has standard suspension [i.e. non-adjustable], do yourself the biggest favour possible and ditch the stock dampers which are awful things. Replace with Bilstein B6 and never look back. Roadholding and ride are so, so much better. I was amazed and wish I had done it years ago.(y)
Clarky
@Invetterate do love a cheap performance mod!! And a battery drill too...match made in heaven! She is on the factory 2 position dampers still, i cannot notice any difference between touring and sport tbh but they are leak free and no error codes so they have a stay of execution for a bit! I have had a few cars on Bilstein dampers over the years ( 4 MR2 Mk2's of various flavours) either on black billies or B8s, and a Mk5 VW GTI too on a B12 kit. They are kinda my go-to as I'm too old for coilovers!
Invetterate
I also upgraded the:
  • anti-roll [or sway] bars to C6 Z51 items with metal end links all of which work rather nicely too!
  • brakes with EBC Slotted discs and EBC Blue Stuff track pads [chuffing heck - do they stop the car well!]
  • remapped with HP Tuners software by Wortec
  • exhaust with catback by Borla and centre section with hi-flo cats by Magnaflow
All good fun!!
Airmass - Quality over Quantity
Looking at Mark's PCM calibration of his C5,
the maximum amount of air and fuel required is only 1.2 grms per cylinder, and that would be at sea-level
so not a of airmass is needed plus GM calls the intake manifold an "air reserve" so reason the stock aircleaner cover does not have a lot of openings
Mark's airmass
That video Marks points to
The C5 is a bottom breather, where C6-C7 gets airflow from the front of the nose
The problem in that video is they cut the radiator shroud way too big and increasing the chance of pulling water into the intake
causing hydrolock which is death of engine
What I do is cut a shallow slot and install a duct register (used in your home for HVAC) that allows adjusting the angle of opening and cut is higher in shroud to be further away from any water
It has been this way in my 1999 C5 for over 22 years and never gotten any water in
So objective is flowing much cooler airmass which is a better charge of cylinders, makes better performance and reduces engine knock
As to shocks, Bilstein had a service where people could send in their Bilstein shocks, and they would rebuild them and also change the valving
as how soft or harder they functioned
For my 99 C5 I went way costly Penske race shocks that are multi adjustable and also had Nitrogen tanks to further allow tuning shock function
depending on road or track conditions
Due to how much I lowered the C5 I had to install bump stops bottom side of shock rods
FYI, I mounted them upside-down as that is less unsprung weight
Tanks shown above radiator shroud housing and on frame for rear ones
Clarky
Not a journey in the C5 as had the family in tow,but went past the Corvette race transporters in France.
Invetterate
That’s British team Steller Motorsport and their C8 GT3R, probably heading back to the UK from the Nurburgring race last weekend.
Spot on Andy! I've actually been in one of their transporters - bloody amazing! Also lucky enough to have sat in the race car too. Full story in the next edition of Vette News 👍
Clarky
A few Christmas goodies going on the car today despite the cold weather! Found out that there was a total of 1 speed nut holding the side markers on..other had mastic. Oh the joy! Rear lettering looks fab and then swapped the valve dust covers for Jake anodised ones too. Have a steering wheel decal to go on but it's a bit chilly for that at the moment!
Clarky
Ordered the correct speed nuts from Andys speed shop ( not a paid link at all, just was cheap and arrived very quickly if any of you need them!) so providing it isn't the minus 4 degrees forecast I might brave putting them on tomorrow!
Clarky
Got round to fitting the steering wheel badge at the weekend. Looks so much better for it!!
C5Steve
Apologies if I missed it but where did you get your steering wheel emblem from? Need to change mine as the little flag ends are lifting but everywhere I look the shipping is insane for such a small thing!
Clarky
Hey @C5Steve it came from RPI design in the US of...luckily we have family out there and this was in our Christmas card. Have you looked at something to restick the badge you already have? It came with a small 3M glue oddity..was a card tube that you squeeze, in that was a sponge tipped plastic tube with a glass phial inside that! Smelt awful/wonderful depending on your point of view! Lol but certainly did the trick
C5Steve
That's very handy! My Mum is visiting the US this year to see family, I may try and get the thing sent for her to bring back.
Thanks for the suggestion, I actually want to swap the whole thing as I prefer the style of yours to mine (mines domed) so good to know where it's from either way. Just can't deal with the postage they want for what will be sent as a letter!
Clarky
So the front bumper is off and going to paint next week...New Maxton splitter to replace the old one too. Would run without but so much damage under the old splitter it would really need a new bumper skin but those aren't easy to get here even with family in the US. Also I now have the harmonic balancer to deal with too!
Would be a good time to do :
1. Lube the bushings for the front sway bar mount & the end links of it
2. Flush out the crap from the A/C condenser and radiator from the outside
3. Lube the pivot points of the headlight doors
4. Clean the small light bulbs
Clarky
So I've taken the time to do a few bits while awaiting the bumper and splitters return on Tuesday. I cleared out a fair amount of the Le Mans campsite grass from last year in the rad intake, put a bit of bushing grease on the ARB bushes ,bit of 3-1 oil on the headlight pivots, and the previous owner gave me an induction kit and as the air filter was a tough full of grass I thought I'd give it a test fit. While I don't think its a particularly expensive kit it is vastly cleaner than the OEM filter and housing and I can swap out the cone filters for something more attractive in the future if I decide to keep it there. The underdrive harmonic balancer has also arrived and as soon as I can get the 'Vette booked in to the mechanic it'll get fitted!
Consider hot air is a lousy charge to the cylinders and can induce more engine knock and leaner AFR which reduces performance
Air filter system you have is not best for that above
Two opposing airflows where the air is spinning and then collide to the MAF can cause it to incorrectly report the amount of airflow and due to the filter system being high and above the hot radiator, plus heat raises that open area in this design means the built-in air sensor in the MAF will report that hotter air and the PCM commanding more fuel use so could lower fuel mileage
The C5 is a bottom breather so it picks up the colder lower air into the airfilter
You notice stock filter is flat surface so no spinning or air, and it caps off the filter to prevent hot engine bay air being pulled into the filter
Some of that can be overcome by what I do in tuning the PCM's calibration
If you do not intend to tune the PCM calibration you will have to drive this dual filter, esp in hot weather and see how engine and fuel mileage are
On another note while front end is apart,
GM took a copy of the build sheet, rolled it up and stuck it in the end of frame on right side corner end
You might see if you can see it,
if still there take it out to flatten out and save
Clarky
So I have had the front end repaired and repainted and I also a while ago bought 2 new/old stock front fogs that the car was optioned with from the factory...however I was expecting to find the small plugs hidden in the loom but that is not the case...is there a separate loom for front fogs/ no front fogs or has it been chopped from my loom...and clues if and where it could be disconnected from? Have looked to see if it was taken vack to the chassis rails behind the bumper cover but nothing there. Any help appreciated!
On the far left of dash do you have the switch for fog lights by the switch for hatch release ?
Do you see on the sticker of console glove box the option T96 ?
Looking at the sticker for my 1999 C5 fog option
Here is the wiring IF the option was included in new C5 purchase
