New to this - C3 THE PLOT THICKENS
Alex Gray
Right, it’s getting a little more confusing.
The red wire that was dislodged from the fuse box was indeed the ignition hot, I’ve reinstated this and proven 12v at the relay control module when ignition on. Ran her up to temperature and with fingers crossed awaited the fans…. They didn’t run!!!
So I wondered if it was the signal from the stat and to try and prove this I jumpered them to chassis ground with ignition hot, nothing!!!!
I started having a look on the power circuit side and have found two inline modules that on closer inspection have burnt out. See the picture attached.
What’s confusing me is “why would these burn out as a result of there being no ignition hot”? As before that was knocked out everything ran like a dream???
My next question is, am I allowed to use these halford bits to replace the inline fuses? They are rated to 30A but I’m not sure if they are suitable for engine bay use??
Was this screwed up when you first bought this C3 ?
If so, sounds like last owner had this problem and was trying to debug it
Inline modules ?
Are those fuse holders, or what their purpose ?
How does this controller know what the coolant temp is ?
Is the wiring like 14 or 12 AWG gage ?
Alex Gray
Hi. Sorry, I appreciate I’m not explaining it clearly so I’ve done a drawing. Hopefully that makes it clearer.
So I reinstated the ignition hot as that had come loose. But further diagnostics found the two fuse blocks (I think that’s what they are) between the alternator and relay box had melted out!
Did you look closely and try and find any label or name on controller or fans as who makes these
to then search on internet for instructions of installing ?
You sure both circuits go directly to the alternator ?
As I asked what gauge are the wires for that, look like 14 or 12 AWG ?
I would think 20 Amp would be fine but could be they are using
20 AMP per relay and fan
Your drawing too dark so I redid it
Could test and use a jumper between the 2 wires of one melted connector and see how that controller reacts
Alex Gray
Thanks, yes no manufacturer label on the controller I’m afraid.
The power circuits are roughly 6mm (so I think roughly 10awg.
The control circuits look like 0.5mm so 20awg.
I’ll jumper the melted blocks tomorrow and see how we go.
OK More info
I think that wiring was too close to engine/exhaust and cause of melting, so move them away
Look at the cooling fans, there should be a amp draw label on them and reason you say wires are like #10 AWG
that would support 30 AMPs per fan
I see others also went to the Alt instead of the car's fuse panel could not handle all that AMP draw
Jumper, 1 or both fuse pair wires and test
I have to think there would be a single pole switch by driver to override the controller
like if racing would not want the fans on and enough natural flow would be fine
Is that melted part a fuse? Surely fuses normally just blow the wire inside them, not melt to ash like that.
The case part isn’t damaged so the heat must be electrical rather than from proximity to headers.
Halfords electrical parts are fine, although I would use fully insulated female spade connectors instead of those ones in your photo that don’t have insulation on the spade.
Have you established if the fans actually run or not, independent of the control module?
