Hope you get it back before winter chuffs.Wish I could go for a blast in the Vette in all this glorious weather but the Purple Peril is currently off the road pending a transmission rebuild .![]()
It has been playing up for a while with not shifting up from first or second especially from a cold start . It changed down smoothly enough from top ( third gear ) but wouldn`t change up again smoothly with power on once warmed up . Once I hit 4000 rpm it would change up to top but with a huge thump and a surge . The fluid level was good but I had it flushed and changed with new filter pan . There was crap in the pan and torque converter . Being a 1980 MY it is electronic lock up . There was still no improvement in the way it drove so a rebuild is lined up .Whatβs happened to the trans?
I had a merc sprinter with auto box that eventually was slipping , a bew filter and trans fluid got me. Couple more months but it then lost reverse gear. 1700 quid for a rebuild back in about 2012It has been playing up for a while with not shifting up from first or second especially from a cold start . It changed down smoothly enough from top ( third gear ) but wouldn`t change up again smoothly with power on once warmed up . Once I hit 4000 rpm it would change up to top but with a huge thump and a surge . The fluid level was good but I had it flushed and changed with new filter pan . There was crap in the pan and torque converter . Being a 1980 MY it is electronic lock up . There was still no improvement in the way it drove so a rebuild is lined up .
I am bracing myself for a bill knocking on the door of Β£4K !!I had a merc sprinter with auto box that eventually was slipping , a bew filter and trans fluid got me. Couple more months but it then lost reverse gear. 1700 quid for a rebuild back in about 2012![]()
Wow, thatβs a big chunk of change, sorry it happened to youI am bracing myself for a bill knocking on the door of Β£4K !!![]()
Really!!? Blimey I was thinking half of that with a few years inflation π«£I am bracing myself for a bill knocking on the door of Β£4K !!![]()
Rising labour costs plus the dreaded VAT really bump things up unfortunately .Really!!? Blimey I was thinking half of that with a few years inflation π«£
Awwe! I nearly went but was drizzly down here so didnt bother! I often eonder if my gauge works as it hardly moves either. But I notice after winding motor over pre starting to build oil pressure that once i pump the gas pedal and she starts, then the gauge needle moves a fair bit to show it is charging.Looking at Mad's photos - good to see that someone else's "Battery" gauge shows bugger all like mine
Friday was Vette to the Vets day to pick up stuff.
Saturday I went to the SW Corvette Club meet at Strawberry Fields. First time going to the meet, and nice to meet everyone. About 160 odd miles round trip, Corvette didn't miss a beat. First time I've done long distance in ages, and forgotten how much it likes to drink fuel - full tank down to an indicated 1/4 tank left(I should look inside the tank to check properly).
Sunday I went off to Watchet, to errr... Watch It..... namely the Flying Scotsman passing through. No photos as I did a video. Which I can't be bothered to upload and link to here, so you'll just have to make choo choo noises and imagine the Flying Scotsman in your head
And that weekend of awesomeness was sponsored by my wife going away for the weekend and taking the child with her. Fun stuff gets done then!![]()
I was hoping you'd come along so I could meet you. Hey hum. It takes around 1 hour 30 to get there from where I live. I left my place and it was a reasonable day, sun out etc. About 20 mins before I get to Strawberry Fields it absolutely chucks it down - queue first proper test of wipers since I installed electric wiper doors and had issues with my wiper override. Handily, it seems my wipers now work better than before - they actually have two speeds now (normal and fast) instead of the previous "slow". I suspect it was a bad earth that now has been fixed.Awwe! I nearly went but was drizzly down here so didnt bother! I often eonder if my gauge works as it hardly moves either. But I notice after winding motor over pre starting to build oil pressure that once i pump the gas pedal and she starts, then the gauge needle moves a fair bit to show it is charging.![]()
Will try to make it next time if you are down. Your fuel figure sounded quite good compared to mine, never worked it out properly but gauge drops pretty quick , I am thinking 12 ish mpg cruising locally with a bit of mildly spirited thrown in the mix but never ragged , probably never revved it over 3250 to 3500.I was hoping you'd come along so I could meet you. Hey hum. It takes around 1 hour 30 to get there from where I live. I left my place and it was a reasonable day, sun out etc. About 20 mins before I get to Strawberry Fields it absolutely chucks it down - queue first proper test of wipers since I installed electric wiper doors and had issues with my wiper override. Handily, it seems my wipers now work better than before - they actually have two speeds now (normal and fast) instead of the previous "slow". I suspect it was a bad earth that now has been fixed.
I suspect that chucking it down put a few people off. Even Rob, the SW meet organiser, decided to come in his Mustang instead because of the rain. After that little downpour it was all fine, and driving home it was really hot.
As Rob will attest to, I can't make it most times. Hence my first time ever going to it, despite owning the Corvette for 9 yearsWill try to make it next time if you are down. Your fuel figure sounded quite good compared to mine, never worked it out properly but gauge drops pretty quick , I am thinking 12 ish mpg cruising locally with a bit of mildly spirited thrown in the mix but never ragged , probably never revved it over 3250 to 3500.
`Little Man` must have been the only one asleep as the whole world seems to go mad at the mere mention of the much hyped `Flying Scotsman ` as the " worlds most famous steam locomotive " !! It nearly bankrupted its three previous owners and the National Railway Museum who now owns it went vastly over budget by several Β£ Millions with its last major overhaul so the publicity machine really needs to keep promoting it and generating lots of operating and hire fees fees both on Heritage Railways and on main line charter trains . Good to hear you had a great time , some piccies would be great .Over the long weekend I had family down for the child's christening.
On Tuesday a bunch of us also went on the Flying Scotsman on the West Somerset Railway. You've all seen the Flying Scotsman before, so I won't bother uploading photos. Good fun day out and also the child's first time on a full sized train..... and he was asleep most of the time on it. When awake, he enjoyed looking out the windows.
Oh ok, as its you. I'll poorly edit some photos so the child isn't in themGood to hear you had a great time , some piccies would be great .![]()
