Yes it is possible when turning the steering wheel when changing fluid that somehow the pin from the CL motor expanded out
that would have sent a signal to say locked and pin is stuck that position and PCM is doing as design and will not turn fuel to injectors on
As mentioned, you might be able to free that pin to close
If your C5 had the CL recall done, with auto tranny someone removed the plate behind the steering wheel which has a small hole
that pin goes into to lock
But that does prevent the pin expanding out so steering wheel still turns but the pin out telling PCM wheel is locked
