Painting my C4
Andrew
Was your process like this?
  1. Sand existing paint – 600 grit, dry
  2. Panel wipe
  3. Mask up
  4. Panel wipe again
  5. Mipa paint – 2 coats
  6. Let paint cure
  7. Wet sand – 2,000 grit
  8. Wet sand – 3,000 grit
  9. FarΓ©cla G360 – wool/high-cut pad
  10. FarΓ©cla G360 – cutting/polishing pad
  11. FarΓ©cla Super Fine – finishing pad
  12. Panel wipe – remove polish residue
  13. Ceramic coating
600 dry β†’ panel wipe β†’ Mipa Γ—2 β†’ cure β†’ 2000 wet β†’ 3000 wet β†’ G360 wool β†’ G360 polish β†’ Super Fine β†’ panel wipe β†’ ceramic.
Steven Smith
  2. Panel wipe
  3. Mask up
  4. Panel wipe again
  6. Let paint cure
  13. Ceramic coating
Yes but panel wipe before initially sanding to remove and polish or wax so as not to sand it into the panel.
Steven Smith
Sorry for the lack of updates but the sanding and polishing has stopped.
My C4 is poorly, went out for a drive in mid September and it broke down.
Lucky I wasn't far from home and was "uphill" so managed to coast and push it home.
After a lot of fault finding I found out that the injectors were permanently on and flooding the engine, it also put fuel into the oil.
After fully testing the fuel system and the ignition system I have traced the fault to the ECM.
I think I have traced the fault to the Mosfet (like an electric switch) that turns the injectors on and off so have a new one on order and will solder it into the board when it arrives, so fingers crossed.
Typically RockAuto won't send a ECM to the UK due to the unknown Russian steel content πŸ€·πŸ»β€β™‚οΈ
Interesting fact is the C4 use's a batch fire system and all 8 injectors fire together, not individually or in banks of 4.
Invetterate
Good luck with it, Steve! I am certain you will get it sorted (y)
Hi Steve - that 'batch' fire system seems really crude in concept compared with more modern systems - is there are value in looking at some of the current aftermarket injection systems (Edelbrock and FiTech?) that do partial MPI kits for use on earlier GM injected engines?
Steven Smith
It would be nice but the budget doesn't allow such extravagant behaviour πŸ˜‚
Steven Smith
The C4 is finally repaired, after replacing the Mosfet in the ECM twice, the TVS diodes in the injector driver circuit and spending hours fault finding the ECM to no avail I eventually managed to get a refurbished ECM from RockAuto via a friend in the US as they still won't post to the UK.
Fitted it today and all seems well, went for a short drive and it's looking good.
