If that is the case then your problem is almost certainly in the electrical system. There are very few non electrical issues that test would show up (flooded plugs for example)I use this Gunson timing lamp. With the engine running I simply fit the inductive pick-up on each HT lead in turn and pull the trigger. If the light doesn't flash then that cylinder isn't firing. If the flash is sporadic or intermittent there's an occasional misfire.
