I'm preparing to re-install my intake manifold and I've noticed that both the old gaskets have heat crossover restrictors fitted. My new Fel-Pro gasket set comes with a restrictor for one side only and i'm wondering if this should actually be fitted and if so, in which side?
(Old gasket below with restrictor fitted - new one above, without.)
The engine is running a stock Quadrajet carb with divorced coil choke on a stock cast iron manifold. It's fitted with headers so has no heat riser valve. Obviously the choke will benefit from some heat transfer to come off - and stay off - as quickly as possible but the carb itself however could well do without any excess heat to avoid early vapourisation in hot weather. ( I've had a couple of occasions when the engine cut out in very hot weather and slow traffic. Restart was only possible after raising the hood and waiting twenty minutes or so. Certainly indicative of vapourisation or percolation.). Modern ethanol loaded fuel is even more volatile than petrol so any potential vapourisation problems are more likely nowadays. I believe the original Quadrajet mounting gasket was a composite affair designed to minimise heat transfer from the manifold but this is very hard to find these days and very expensive if you can, so I have only a standard thick gasket to mount my carb.
There appears to be a trade off between allowing enough heat through to actuate the choke properly but not so much that there may be fuel percolation problems in the carb.
...Web wisdom suggests that with my set-up the best compromise is having the crossover restrictor fiitted but only in the drivers side gasket, leaving the passenger side clear.
So, unless anyone can offer a better suggestion, that's what I'll try.
